hagemeijer
export and import 'negative' polyline
Hello forum,
I have a polyline object with another polyline cut out of it. If I traverse the poly in vectorscript with vertexNum and GetPolylineVertex I only get the surrounding points, not the one that make the cut out part.
How do I get to this part of the polyline?
Thanks!
Thank you Joshua, strange I didn't see that before...
I have another question for the creation of a polygon and or polyline:
with getObjectVariableInt (h, 696) I get the fill type of the polygon.
If I want to set the type with  setObjectVariableInt (h1, 696, str2num(s)) where s is "2" for a solid color I get an error that constant 696 is not supported for the handle. h1 points to a kpolylinenode.
Can someone please help me with how to set the fill type?
Hello Raymond,
695 works ok! The confusion is style vs type...
I am building a way to select items in a drawing, export these to a text file and reproduce the drawing from the text file. The text is stored in a database and I can be selected from the database to add to a drawing, to add details to the main drawing.
Creating an arc can be done 2 different ways but I think center and radius is the easiest. Does anyone have a solution to get the radius of a drawing. I must be again missing something, but I can't find a objectvar or procedure to get it...
You may want to try File>Export>Script. This will show you what data gets set via direct function call verses object variables. For most Set... commands there is a corresponding Get... command.
Typically you want to look at the function reference first, and only look at object variables when they are not otherwise obtainable with a command.
This is a little less obvious with an arc. You can use Get2DPt to get the center (index 1) and a point on the arc (index 2) and calculate the radius. http://developer.vectorworks.net/index.php/VS:Get2DPt
@hagemeijer ,
   If you have a handle to an ARC (or CIRCLE) object, you can't GET the radius directly, but you can calculate it:
      GetArc(H, Start, Sweep);
      Radius := hPerim(H) / Deg2Rad(Sweep);
where "H" is the handle to the object.
OR as Josh says:
    Get2DPt(H, 1, Pc.x, Pc.y);
    Get2DPt(H, 2, P1.x, P1.y);
    Radius := Norm(P1-Pc);
where "H" is a Handle to the object and Pc and P1 are Vectors.
Raymond
