Hi guys,
I am trying to trace over this plan using bitmap (this is actually my first time doing this) I need to red-draw the plan at scale 1:50 which is now to scale.
I have uploaded the PDF and re-scaled to size. So far so good. Now I tried to go to Modify --> Trace Bitmap and this pop up comes up  "A Bitmap object must be selected".
Can you please help why I am doing wrong?
Thank you for your help.
Edited by Julian78
The system is telling you it wants a bitmap - a .pdf is not a bitmap - you need a .jpg or similar image file.
Do you have the original vector-based pdf that your notes are drawn on? Just explode it and build your drawing from that.
@unearthed I think I have managed! I simply converted my pdf to a bitmap file and then rescaled to size. Let's see how I get on now (this is my first time doing this).
Thanks though.
I have then selected modify --> Trace Bitmap ( using the bitmap file as above) --> The pop up box is set to 4 and medium. And then it seems the computer starts struggling (or worse crashes) and I get these crazy lines all over with no snap points.
 Does anyone know why?  Or is there any alternative to get those snap points to I can trace over some of the plan?
Hope someone can help!
Thanks
@Nikolay Zhelyazkov Sure thank you so much!   This is the bitmap file which once I upload to VW I would need to resize to 1:50.but I can't upload it on here so let me send you the pdf (but this is not a vector pdf) instead - I need to redraw only the outlined red area.
Maybe I am doing something wrong?
plan.pdf
@Nikolay Zhelyazkov Thank you can you please explain how you did it?
I cannot open the file - see screenshot sadly!
Do you convert that pdf to become a bitmap object? If I upload the bitmap image of the pdf file it won't work.
@Nikolay Zhelyazkov Thank you very much. The tool does pick up on all the lines! Very accurate, although the lines are serrated but nevertheless this is a big help. Thank you. Is this a tool that is being developed by VW Inc?
Again, much appreciate this, I was trying to trace over a new design layer and this is so time-consuming.
On 1/15/2020 at 4:10 AM, Nikolay Zhelyazkov said:
Glad to help. 🙂
- Yes.
Will this new tool be Available in VW 2021?
Hello @DBruhnke,
- The tool is just a demo and it is still not certain if it will be released in any of the future versions or not.
Best Regards,
Nikolay Zhelyazkov
@Nikolay Zhelyazkov Upon further review...
While the conversion is better with fewer anomalies, for the most part, this type of conversion for raster PDF files is not much use.
None of the lines are really usable.
Perhaps there is another solution in the works in lieu of the enhanced Trace Bitmap?
Hello @DBruhnke,
I am sorry to hear that the provided example did not help.
I do not know of any other way to get better results.
You could ungroup the result from the file I have sent you and delete the parts that you do not need, such as texts.
Better results could be given with a clearer scheme with higher quality and maybe less details.
Best Regards,
Nikolay Zhelyazkov
@Nikolay Zhelyazkov The trace bitmap is perhaps helpful for logos or non technical drawings.
For linework on a plan, elevation or detail, something like Scan2CAD capabilities would be amazing.
Not tracing the outside of the lines but creating the lines themselves.
https://www.scan2cad.com/
While nowhere near perfect, this software has the ability to "convert" a line instead of "tracing" both sides.
#JusSayin
Untitled.dwg
