SWarc
Walls Still Associated with Deleted Roof
Hi,
I created a mono-pitched roof element, subsequently associated with the walls below.
As expected, the walls took the form of the roof however when I deleted the roof, the walls maintained the slope and height which came about due to the association (see walls to the left in the screenshot attached) Is it possible to revert the walls to their previous height? Probably an obvious solution but any help much appreciated.
S
Walls are not "Associated" with roofs in there is no permanent link that when one is changed the other changes also.
Check out this thread for information on different methods to remove Wall Peaks to get back to something you can use.
Thanks Pat, I found the answer there (delete wall peaks..).
