josue Corona
center any 2D & 3D object
Does anyone know if there is a way to center a 2d or 3d object between to  two lines/points. or if someone knows a script that can do that?
Thank you
You can use the smart points snap. With snap points on in the snap settings, grab an object at the center point, hover over point one for a second or so till a snap appears, hover over point two till till a snap point appears, a dashed snapping line should appear between the two points. You can then place your object on the midpoint of this line.
Check out Align and Distribute with your objects preselected. Cmd/ctrl + =
Edited by EAlexander
