MartinFahrer Posted January 10, 2020 Share Posted January 10, 2020 It seams that when I use this button I get a 1:48 engineering type scale instead of the standard fraction in an architect scale 1/4"=1'-0". I don't know why it doesn't match what is shown as my scale in the viewport. See attached images 1- What I see 2-What I want 3-Viewport Quote Link to comment
0 Patrick Fritsch Posted April 25, 2024 Share Posted April 25, 2024 On 10/25/2023 at 11:38 PM, Nikolay Zhelyazkov said: This is a bit tricky to achieve, but it is possible: 1) You need to have a drawing label in the viewport, which displays the scale in architectural format. Then the TBB will display the same as the drawing label 2) If you are in a metric document you will have to switch to imperial units to get the drawing label and TBB display the imperial architectural scale Already a better explanation Nokolay...but....this still needs to be more flexible...a lot of wasted time doing something SO tedious. 1 Quote Link to comment
MartinFahrer
1- What I see
2-What I want
3-Viewport
26 answers to this question
