Multiple geometry as input into network.
Hi all!
Is there a way to import multiple geometry into network in the same way, as it works for Control Geometry node?
E.g. there are 3D points created by hand (as loci). I want to use them as starting points for geometry generated by network, but at the same time I want to keep the ability to relocate them (just like control geometry works but for multiple objects).
Tried to use polygon as an input and read its corners as desired 3D points, but this method fails, if there is a need to use two or more sets of points.
Thanks for any help!
