Robby54 Posted August 18, 2005 Share Posted August 18, 2005 Line arcs are printing as segmented straight (and sometimes wavy) lines from both a HP DesignJet and LaserJet. Also displays this way on screen. This does not happen when drawing a circle. Any insight would help. Using: VectorWorks 11.0.1 Mac OS 10.3.9 HP DesignJet 110 Plus nr HP LaserJet 1300 Quote Link to comment
islandmon Posted August 19, 2005 Share Posted August 19, 2005 1) Make sure that you are using the OSX GIMP drivers. 2) Goto VW preferences and set the 2d Conversion to medium or high. Quote Link to comment
RGyori Posted August 19, 2005 Share Posted August 19, 2005 An additional item to check: in the print dialog box, navigate the drop-down menu to "Vectorworks" and make sure your "application print resolution" is set at 360 dpi (preferred). Good luck! Bob Quote Link to comment
altoids Posted August 19, 2005 Share Posted August 19, 2005 What happens when you print to a PDF, then examine the file in Preview? Quote Link to comment
islandmon Posted August 20, 2005 Share Posted August 20, 2005 The print2pdf preview displays the exact printed page produced by VW. If you then send it to the printer and something is missing then the problem is with the printer. Quote Link to comment
