Mirror VS Plastic
Tanner Shelton
I mostly use the Glass reflection only.
AFAIK it has also a Roughness feature.
And by its additional Gray values it helps to mimic a Fresnel Effect.
Meaning, like in reality, dielectric Materials have less Reflection when
you look straight to them vs looking along their Face.
And our Building Materials are mostly dielectrics, very seldom pure
Metals.
If I want to do it more realistic if something is important, I play with
the new Metal Shader.
Where I only use the "clear coat" part for Dielectrics.
Ah that makes sense. And modern PBR states that every material has a fresnel and specularity, but dielectrics just have a very minimal amount of specularity. I've been trying to figure out how to accommodate this line of thinking within Vectorworks. With the glass shader, though, are you able to use any kind of specular map? (I'm used to the roughness metal workflow)
I'm trying to use the metallic shader as Zoomer suggested he does sometimes, where I use it to get a fresnel and roughness on a dielectric material for more realistic rendering. My main issue is I can set the roughness and speculiarity to what I need, and it looks great, especially with my normal map, but the actual color data from my image texture doesn't show through.
Edited by Tanner Shelton
Dielectrics have a "Diffuse" value or color.
Basically still just reflections, but in arbitrary directions as the Photons
can enter the dielectric material and get spread.
At least I was able to create a red plastic material with the Metallic Shader
nevertheless. Hope the screenshot in that linked post contains all necessary
settings to misuse that Shader for Dielectrics.
As I don't remember anymore what I did there.
But that is again a workaround that tries to work against the App.
I am in most cases very happy with the results of the Glass Reflection Shader
fake.
Or I am also very happy with many of the delivered Arroway Materials, which use
just interesting Image Textures to control Reflection amounts.
(Although there isn't any Fresnel effect at all)
Edited by zoomer
I solved the issue, it required changing the color of the metal in the metallic shader to 100% black. When changing that, it no longer rendered the black diffuse and instead rendered my image texture. Rendering time didn't seem to be much longer then the glass shader as well, so might be something I will try fully on my next project for all dielectrics and see what type of impact it has on rendering time and how much it improves the overall quality of the render.
I wasn't sure about that as I never tried a Texture.
Thanks,
so I know it works.
If you have Fresnel (= 100% Reflection at glancing angle) then yes.
Dielectrics have very low Reflections when you look perpendicular to a Face.
Maybe 5-8% may look better in a Rendering.
But if there isn't a Fresnel Feature or angle dependency, I would better go with
something like VW's Glass Shader.
In pre PBR times in 3DSMax, without such options, I was used to have unrealistic
Reflection values of 40% to mimic Glass and Plastic 🙂
Did some tests and rendered the scene. The first is just a plastic shader with roughness and the second has every material using the metallic shader clear coat options. You can tell that the reflections are a bit more accurate with the metallic shader, but not a big enough difference to be worth the increase in rendering time. I really wish they had a reflectivity shader with roughness, reflectivity, and fresnel. So basically the glass shader but with the addition of roughness. Blurriness is okay, but setting roughness looks much more realistic I think.
Plastic Shader (Render time 10 minutes)
Metallic Shader (Render time 50 minutes)
