Sam Jones
Not Reporting Param State Changes
I am under the impression that when a parameter is changed the result of
ParamChangeFlag := vsoStateGetParamChng(PIOHan,ParamChangeWidget,ParamChangeIndex,OldParam);
should be true.
I have a PIO that fails to change the ParamChangeFlag  to true when a parameter changes.
My init event has the following code.
            kObjOnInitXProperties:        {5}
                BEGIN
                    Result := SetObjPropVS (kObjXPropHasUIOverride,True);
                    Result := SetObjPropVS(12, TRUE); {kObjXHasCustomWidgetVisibilities}
                    SetPrefInt(590, 1 ); {kParametricEnableStateEventing}
                    Result := SetObjPropVS (18,TRUE);    {kObjXPropAcceptStates}
                    Result := vsoInsertAllParams;
                    Result := SetObjPropVS(kObjXPropDataNameDisabled, TRUE);{kObjXPropDataNameDisabled}
                    SetPrefInt (590,1);    {varParametricEnableStateEventing,ResetStatesEvent}
                END;
Which should enable state eventing.  Does anyone have a clue as to what I missed or where I should look, because now
always yields False whenever a parameter is changed in the OIP.,
Hi Sam,
   Do you have your call
           ParamChangeFlag := vsoStateGetParamChng(PIOHan, ParamChangeWidget, ParamChangeIndex, OldParam);
in Event 3 (kResetEventID)?
Everything else you have in your kObjOnInitXProperties event is what I have, though you call
twice, where I only call it once at the end of Event 5 (kObjOnInitXProperties). I doubt it makes a difference, but I don't know.
   Also, do you have "Event-Based" checked in the "Edit Plug-in Definition" dialog, Options tab?
   Lastly, I execute these 3 commands first before I enter the CASE statement testing the events:
      result := GetCustomObjectInfo(PIOName, PIOHand, recHand, wallHand);
      IsNew := IsNewCustomObject(PIOName);
      vsoGetEventInfo(theEvent, theMessage);
The first line makes sure the PIOHand variable is valid, and the third line returns the current EVENT.
Raymond
Raymond,
Thank you.  The kObjOnAddState event was indeed missing from the event case test; however putting it in did not solve my problem.  Nothing I can do it seems will yield
ParamChangeFlag = True
Here is the guts of my main with the case event test.
        GetVersion(Major,Minor,Maintenance,Platform);
        GetUnits(Fraction,Display,Format,UPI,UnitName,SquareName);
        Result := GetCustomObjectInfo(PIOName,PIOHan,PIORec,WallHdl);
        vsoGetEventInfo(EventMessage, MsgData);
        OK := GetLocalizedPlugInName(PIOName,LocalPIOName);
        BoxBottom := 3 * UPI;
        CASE EventMessage OF
            kResetEventID:                {3}
                BEGIN
                    GetSymLoc3D(PIOHan, PIOX, PIOY, PIOZ);
AlrtDialog(concat('Event 3, kResetEventID  triggered', kcr,
                'ParamChangeFlag = ', ParamChangeFlag, kcr,
                'EventMessage = ', EventMessage));
                    IF (ParamChangeFlag=True) THEN
                        BEGIN
                            {Do Stuff}
                         END; {IF (ParamChangeFlag=True) }
                    ParamChangeTrig := FALSE;
                    PIOChangeTrig := FALSE;
                    SetUp;
                    MainConstruct;
                    vsoStateClear(PIOHan );
                END;
            kObjOnAddState: {44}
                BEGIN
                    {This event is needed to track state changes}
                    EventMessage := vsoStateAddCurrent(PIOHan, EventMessage);
AlrtDialog(concat('Event 44, kObjOnAddState  triggered', kcr,
                END;
                BEGIN
                END;
            kObjOnWidgetPrep:    {41}
                BEGIN
                    WidgetPrep;
                END; {kObjOnWidgetPrep}
        END; {case}
Hi Sam,
   I have only two suggestions which I've marked with comments in your code. Try them one at a time to see if either of them works. Then try them together if neither works. After that, I'm out of ideas.
		kResetEventID:		{ 3 }
			BEGIN
{ MOVE vsoStateGetParamChng LINE FROM EVENT 44 TO EVENT 3 }
				'EventMessage = ', EventMessage, kcr,
				'MsgData = ', MsgData));
					BEGIN
						{Do Stuff}
				SetUp;
				MainConstruct;
			END;	{ 3 - kResetEventID }
		kObjOnAddState:		{ 44 }
			BEGIN
{ CHANGE EventMessage TO MsgData (x2) in following line }
				MsgData := vsoStateAddCurrent(PIOHan, MsgData);
			END;	{ 44 - kObjOnAddState }
		kObjOnInitXProperties:		{ 5 }
			BEGIN
			END;	{ 5 }
		kObjOnWidgetPrep:    { 41 }
			BEGIN
				WidgetPrep;
			END;		{ 41 - kObjOnWidgetPrep }
	END;	{ case }
Have a Merry Xmas, (or holiday of your choice),
Raymond
{ CHANGE EventMessage TO MsgData (x2) in following line } seems to be the key to the problem, and I have things working now.
What is "MsgData := vsoStateAddCurrent(PIOHan, MsgData);" reporting?  It would seem that the only statement needed on a
"kObjOnAddState"
is
Hi Sam,
   That's the change I thought would have the most impact on your problem, yet I'm not exactly sure what vsoStateAddCurrent() does under the hood. It's one of those things that works and I have not spent any time trying to figure out more about it.
   As you surmised, that is the only statement I have under that event in all of my PIO's. If you ever find another example on how it's used differently, please let me know.
Happy New Year,
Raymond
