josue Corona
rectangle stretch in increments
Hello is there script I can make that I can stretch a rectangle in increments ? it can be 2D rectangle. As for the size of the rectangle I could just type it in the object info palette?
The increments would be a one way stretch.
Thank you
Can we know what your end result might be? Why are you needing this? It gives a direction to work in.
Do you want the original to grow, or do you want a duplicate each time it grows?
Hello WhoCanDo and Larry,
and yes (whocando) basically that's what I am trying to accomplish, that the object to duplicate itself, next to each other as I stretch the rectangle but it will stretch in its own increments. The size of the starting rectangle can be determine in the object info.
Larry Can the grid spacing be determine if I try that alternative for now?
I'm still not understanding your intention, but I'm guessing the following. Draw a rectangle and leave it selected. Run the macro and the elastic band will determine X and the location of the new rectangle.
procedure Stretch_and_Move;
var
pt1, pt2 : vector;
wth, ht : real;
begin
if (Count (Sel = True) = 1) then
  begin
  pt1.x := LeftBoundN (Sel = True);
  pt1.y := TopBoundN (Sel = True);
  wth := Width (Sel = True);
  ht := Height (Sel = True);
  DSelectAll;
  GetPtL (pt1.x, pt1.y, pt2.x, pt2.y);
  RectangleN (pt2.x, pt2.y, 1, 0, pt2.x - pt1.x, -Abs (ht));
  end;
end;
run (Stretch_and_Move);
Edited by WhoCanDo
Revised RectangleN values
The grid spacing is easy to determine or set by double clicking the snap to grid icon. This will the bring up the smart cursor options allowing you to read the current spacing and change the grid spacing.
