david p Posted August 12, 2005 Share Posted August 12, 2005 i'm looking for a stone veneer hatch. does this come in the Architect package? Quote Link to comment
CipesDesign Posted August 12, 2005 Share Posted August 12, 2005 There are a couple of options in the Architect (or Landmark) module(s). Yes there are a couple of stone symbols (not hatches), or you could probably use the "hardscape" tool. You might also try the following website StoneCad Ithink if you poke around you can find what you need.... Hope that helps :-) Quote Link to comment
islandmon Posted August 13, 2005 Share Posted August 13, 2005 You can allows use an Image it works really well ... believe me. Just takes getting used to. Quote Link to comment
david p Posted August 15, 2005 Author Share Posted August 15, 2005 thanks for the tips Peter & EJ Quote Link to comment
david p Posted August 15, 2005 Author Share Posted August 15, 2005 I'm trying to use the Tile command, but i can't produce the results of the example on page 9-7 (architect). if i draw a rectangle the command works, but if i drawn a polygon like the sample it will not work? the symbols of the stone veneer was exactly what i was looking for! it would be great if i could figure out how to use it! Quote Link to comment
CipesDesign Posted August 15, 2005 Share Posted August 15, 2005 Seems to work fine for me, even with an open polygon. Are you sure you are 1) Selecting symbol first, then going to AEC>TILE? 2) Using a polygon as opposed to a polyline (you can convert a polyline to a polygon with the TOOL>CONVERT TO POLYGON command). Hmm... Quote Link to comment
david p Posted August 15, 2005 Author Share Posted August 15, 2005 quote: Originally posted by CipesDesign: Seems to work fine for me, even with an open polygon. Are you sure you are 1) Selecting symbol first, then going to AEC>TILE? 2) Using a polygon as opposed to a polyline (you can convert a polyline to a polygon with the TOOL>CONVERT TO POLYGON command). Hmm... I think i needed to convert the polyline to polygon, but it was taking to long to tile the stone pattern. maybe it is my machine? thanks Peter Quote Link to comment
CipesDesign Posted August 16, 2005 Share Posted August 16, 2005 Yes, that stone pattern/symbol is quite complex and so it is not surprising that it would take a while. What machine are you working on? Quote Link to comment
david p Posted August 30, 2005 Author Share Posted August 30, 2005 quote: Originally posted by CipesDesign: Yes, that stone pattern/symbol is quite complex and so it is not surprising that it would take a while. What machine are you working on? PowerPC G4 384 MB DDR sdram i need to upgrade with the ram Quote Link to comment
CipesDesign Posted August 30, 2005 Share Posted August 30, 2005 Yes. In fact there are even times that my setup seems too slow :-( - It is is little like a see-saw: first harware is faster (and can keep up with the sofware) , then software is more demanding (and makes the hardware seem very slow)... Quote Link to comment
islandmon Posted August 30, 2005 Share Posted August 30, 2005 Clever and creative and resourceful we all must be... Quote Link to comment
