ccalhoun
Able to convert to wrapper but not object node
Hello, I am trying to convert my wrapped marionette node into an object node. When I run the wrapped node, the network works as expected. However, when I convert it to an object node, I get an "invalid callback function parameter type". Can someone explain to me why this error is occurring. I have attached my file below.
Box step_Side V2.vwx
@Marissa Farrell Ok, so I made a custom node (Side Support Profile) that creates a composed 2d profile of the stair support. I am able to convert that into an object node. However, when I add an extrude and rotate3D node to the equation I get the same invalid callback function parameter as before. The only thing I can think of that's causing the problem is the duplicateObject function present in the extrude node.
Side Support Custom Node.vwx
I was able to get the object node working by using the polyline function instead of the LineTo function within my custom node.
