VW 2018 - "The file save operation failed" when saving to network
angelojoseph
This was posted under the 2018 thread, but I am having the issue on 2020 VW Designer. I have been having this issue now for several weeks. Updated to 2020 and it did not solve the problem. I get "(failure to attempt to write to file)" in a window 4 times in a row. That is, clicking ok only brings the warning up again four times.
Then a final message box that says:
"An error occurred while saving this file.
This file is now corrupt on disk. Try saving this file to a different location. If you close this file before you successfully save it, it will be completely lost"
I am the only one with the issue in the office. I have no other issues saving to the sharepoint in other software
I can save the file to my hard drive and then drag it to the shared folder with no issues.
1 answer to this question
