fuberator Posted December 10, 2019 Share Posted December 10, 2019 Hi As of late I cannot use the tools in vision. Clicking on the tools in the toolbar just selects them but they do not activate. They stay selected until I quit. I can still rotate the scene with ctrl-middle mouse button. please advise Quote Link to comment
Vectorworks, Inc Employee klinzey Posted December 10, 2019 Vectorworks, Inc Employee Share Posted December 10, 2019 @fuberator Make sure you don't have a dialog, like the Vision Preferences, open in the background. Several dialogs in Vision put you into a restricted view where you can navigate but not switch tools. Does this happen all the time or only when lights actively changing in the scene? What connection protocol are you using? Do you have any other applications running? Try opening up one of the demo files included with Vision and play the pre-recorded DMX. Make sure tools work correctly in the sample files. If everything works correctly in the demo file then please contact tech support and send them your file with some dmx recordings if we need them to reproduce the problem. We have tested on the same OS you are running but not on the same hardware. If you have issues running the demo file let us know and we will see if we can reproduce the issue on similar hardware. Quote Link to comment
fuberator Posted December 10, 2019 Author Share Posted December 10, 2019 Hello and thanks for your reply I do not have anything connected to this machine, so protocol is whatever is default. I only use it to import geometry and then run it on a PC for programming, which works fine. This problem has occured since I first installed Vision 2020. There are no open dialogs behind or in front, and I am trying a completely empty scene, and I also tried re-installing. cheers Quote Link to comment
Vectorworks, Inc Employee klinzey Posted December 12, 2019 Vectorworks, Inc Employee Share Posted December 12, 2019 @fuberator We are searching our office for similar hardware so we can test and see if it's something hardware specific. One more thing to try. Try switching out of dark mode. If it works OK then try switching back to dark mode and see if the problem still exists. There was a strange issue with dark mode that solved itself by going into light mode and did not return when we switched back to dark mode. Quote Link to comment
