Contour node and intersected solid not working as planned
Hi, all!
I wanted to work through a contour node and found something that bothers me.
If the input object is a solid with a hole in it, the contour node creates multiple objects ( a general contour and a hole contour). In my example on layer 001 there is an solid, that works fine. On layer 002 there is a solid with a hole and contour node doubles sections.
Is it possible to manage output of contour node to create clean sections (if there is a hole it should be included as one object or group?) as intuition suggests?
Contour.vwx
