Christiaan
Door vision panel missing in 3D
5 answers to this question
---- deleted content, irrelevant, see better answer below. It's annoying that VW doesn't allow posts to be deleted from the VW forums.---
Edited by Gilbert Osmond
irrelevant
It looks like the vision panel you had defined was too wide for the leaf width, when taking into account the 120mm offset from the strike.
By making some changes to the panel dimensions I was able to get a panel to show as-expected.
You might also want to un-check "Show leaf as solid slab" in 3D detail levels, although by default this only occurs if the overall view level  is set to "Low" detail.
(Note: I made these changes on a door which I had converted to Unstyled.)
2073039030_ScreenShot2019-12-06at6_10_39PM.thumb.jpg.5c7a057763ba1aa6bf406f7180e7ce2c.jpg
95947227_ScreenShot2019-12-06at6_10_56PM.thumb.jpg.e26be7057c84a41a7d93fe112317e2d2.jpg
1617767612_ScreenShot2019-12-06at6_11_02PM.thumb.jpg.30331972f83e90caaf3c862c5e0807fd.jpg
16 hours ago, Christiaan said:
P.S. you should be able to delete your post by clicking on Options
Hmm. For some reason, "Options" doesn't show in my list of available items, thus I have no way to select "Delete"  Perhaps it's something to do with my access "level" on the VW support forums?
691002812_ScreenShot2019-12-09at5_39_53PM.thumb.jpg.4e7f3100820c224f8baf273a4e2cf215.jpg
