We use roof faces, often to model existing buildings that we are extending. There is an existing situation where the clay tiled roof has a slated tile edge detail. To model this, we modified a typical build up to create two component layers in the roof face; a lower 'finish' for the slate with an upper 'finish' of clay tiles. We then used the component offset to pull the clay tiled edge away from the eaves.
Orbiting in model space, all looks fine. However, the offset is incredibly glitchy, and will often bug-out leaving the top layer of clay tiles invisible. On all viewports, as 2d or 3d projection, in open GL, renderworks or hidden line, the upper clay tile layer disappears. This does not appear to be a class issue - purely a problem when offsetting components.
Can we do anything about this without remodelling different pieces of roof face for the different finishes? Also I'd note; we've started playing with Twinmotion and there seems to be no issues with the imports into there.
Looking correct
After editing bound offset - top layer has disappeared
Viewport (in open GL) - tiles have become invisible (you can see the hard 'hidden-line' outline where they should be)
JPM
Hi all,
Looking correct
Settings within roof face dialogue
Vectorworks 2020 Sp2.
0 answers to this question
