TomKen
Publish command is printing sheets in reverse order
In Vectorworks 2020 when I select multiple sheets to print the order gets reversed.
In the attached image on the left is a list of sheets 1 to 5 when I select them and send them to the publish list on the right the order is reversed from 5 to 1.
This means I have to select each sheet one a time to get them in the correct order.  Not a problem for a small project but most of my projects have 70 to 100 sheets.
Anybody have an idea what is causing this?
you can activate "by name" order by clicking the "name" header, you should see little arrow on the right hand side of the header
Clicking on the name button did reorder them for me.  But I would still like to know why it is reversing the order of the drawings.   This was not the case in previous versions of VW.
I just tried and it is not reversing order for me here. VW2020 SP2, Mac OS.15.
What happens if you create a new file and add 5 blank sheet layers (Create 1 and duplicate 4 times)? Do those show reversed? If not, it is something with your file or your template file.
If they do show reverses, check your printer drivers and see if there is something there set to print backwards. The printer driver should not have anything to do with the Publish, but you never know.
Is this 2020 native or from previous versions of VW? Just wondering if something is "lost in translation".
Pat,
If you look at the image in my post you can see that the first thing I did was to start a new document with five blank sheets.  I did this to see if it was an issue with my file.  I'm working on a Window's 7 machine,  I opened the same file on a Mac and we didn't have the same issue.
Has anyone resolved this? Also working in Windows, VVS 2020 and it only starter to happen when I upgraded to 2020.
I have the same problem.
Impossible to print in the desire order tough because it reverse it automatically when I hit Publish button.
Win 10 pro V2020 sp2 Australia. ( Btw this update is a nightmare, crash 10 times a day. I spend half of the day hitting Ctrl+S)
Same Problem...
Added Sheets one by one in revers order solved the problem
notice the sheet#  on the right side column is equivalent to the order you add them - This will be the order of the sheets in the generated PDF
Hope by next SP problem will be solved...
Hello,
This is a known Windows only problem. Our engineers are already working to fix it.
Thank you for reporting!
  • Like 3
A fair amount of time has passed since the last post... I have have the problem? Is there a work around or solution yet?
I still have the same problem.
We have discovered that if you individually transfer the sheets over to publish in the order that you want then they do not automatically reverse. This is long winded and annoying but only result so far.
We contacted Vectorworks Service Select who said they have no record of this being a problem.
Posted (edited)
What? No record?
I am doing what you are doing and it is annoying.
I sent Premier VW Service and email.
Edited by leecalisti
What? No record?   That is not true  Nina in this thread  said it is a known issue and they are working on it.
It was most likely an oversight from our support specialist. My apologies.
On the other hand, this issue has been fixed in SP3. Release date mid-March. 😉
  • Like 4
