Autorotate not working in Renderworks v2020
Allen Brown
No solution, but confirming:
That image used in image prop with image color and image transparency mask breaks bad in some, but not all, RW modes.
I started with the posted v2020 file.
•  OGL = Auto Rotate works as expected
•  FQRW = re renders after every view change, then Prop is rotated as expected.
• Realistic Exterior, Fast = Prop splits into cross plane, no auto rotate, Transparency mask is wonky.
I also tried creating a new image prop from the image (image color & image transparency mask)
This new prop is no better than the original.
-B
