Kevin McAllister Posted November 25, 2019 Share Posted November 25, 2019 Is anyone else seeing random loci appearing when using "Open From" with Softgoods objects in VW2020? Here's a screen shot and an example in a clean file. (I think the loci are supposed to be drawn at the edges of the opening since X and Y in the image are equal and the loci change depending upon the opening width.) @klinzey is this a known issue? Thanks, Kevin Soft Goods Bug 20191125.vwx Quote Link to comment
C. Andrew Dunning Posted November 25, 2019 Share Posted November 25, 2019 Those loci are related to Braceworks. Quote Link to comment
Kevin McAllister Posted November 26, 2019 Author Share Posted November 26, 2019 4 hours ago, C. Andrew Dunning said: Those loci are related to Braceworks. Do you know what they represent and why they only seems to appear when the drape is open? Is there a way for non Braceworks users to turn them off? They are quite distracting. Thanks, Kevin Quote Link to comment
markdd Posted November 26, 2019 Share Posted November 26, 2019 If you go to the Spotlight Preferences in the new Loads and Rigging section, you can choose to automatically assign the distributed loads points to another class which you can turn off, or just turn off the Braceworks-Load class. Braceworks bits and pieces seem to have inveigled their way into so much now..... 2 Quote Link to comment
Kevin McAllister Posted November 26, 2019 Author Share Posted November 26, 2019 6 hours ago, markdd said: If you go to the Spotlight Preferences in the new Loads and Rigging section, you can choose to automatically assign the distributed loads points to another class which you can turn off, or just turn off the Braceworks-Load class. Braceworks bits and pieces seem to have inveigled their way into so much now..... Thanks Mark. This is helpful information. I hadn't noticed that Braceworks had added a class. Kevin Quote Link to comment
C. Andrew Dunning Posted November 26, 2019 Share Posted November 26, 2019 57 minutes ago, Kevin McAllister said: Thanks Mark. This is helpful information. I hadn't noticed that Braceworks had added a class. An option: Add that Class to your Template and make it invisible in all of your preset Saved Views. 2 Quote Link to comment
Kevin McAllister Posted November 26, 2019 Author Share Posted November 26, 2019 It looks like I'm not the only one puzzled by these loci - Kevin Quote Link to comment
Sam Jones Posted November 27, 2019 Share Posted November 27, 2019 They also show up in VW's cable runs. Quote Link to comment
Kevin McAllister Posted November 27, 2019 Author Share Posted November 27, 2019 And here's another related post - KM Quote Link to comment
scottmoore Posted November 28, 2019 Share Posted November 28, 2019 “BraceWorks....” (say it just like Seinfeld said “Newman”) 1 Quote Link to comment
SCDStudio Posted November 30, 2019 Share Posted November 30, 2019 @Kevin McAllister Thank you so much! That worked. I was pulling my hair out trying to figure this out! Quote Link to comment
