APE Design Ctr Posted July 28, 2005 Share Posted July 28, 2005 I just tried the update to 11.51. I have skipped the 11.5 update since i had endless problems with it, and went back to use 11.01. Seems like the issues I was experiencing are solved, but ohhh man this program is slow in OpenGL, and rendering compared to 11.01.! Is it just me? Quote Link to comment
islandmon Posted July 28, 2005 Share Posted July 28, 2005 VW11.5.1 is workin' jus fine out here on the frontier ; ) No issues whatsoever with OpenGL. Quote Link to comment
Guest Posted July 29, 2005 Share Posted July 29, 2005 Run disk utility to see if that helps. Quote Link to comment
Administrator Pharr Posted August 2, 2005 Administrator Share Posted August 2, 2005 quote: Originally posted by APE Design Ctr: I just tried the update to 11.51. I have skipped the 11.5 update since i had endless problems with it, and went back to use 11.01. Seems like the issues I was experiencing are solved, but ohhh man this program is slow in OpenGL, and rendering compared to 11.01.! Is it just me? Can you send me a file which demonstrates this? Do you have any numbers describing the slowdown? We'd love to hear more. Thanks, Paul Pharr CTO Nemetschek North America pharr@nemetschek.net Quote Link to comment
APE Design Ctr Posted August 2, 2005 Author Share Posted August 2, 2005 It seems to be with all my files. I have used 11.01 for the last 6 months, and I know how fast it is. Rendering times are definately slower in 11.51 even though I cant qualify, or quantify it. Quote Link to comment
islandmon Posted August 2, 2005 Share Posted August 2, 2005 APE ... the transition from 11.01>11.5 requires the replacement of many of the plug-ins. My experience was similar to yours especially with OpenGL until I was able to identify and replace the offending 'legacy' tools. Result>numerous kernel panics. Now things are humming along ... and I much more aware of PIO & font issues when accessing older files and importing DXF/DMG. Quote Link to comment
APE Design Ctr Posted August 3, 2005 Author Share Posted August 3, 2005 Thank you. Quote Link to comment
DDDesign Posted August 4, 2005 Share Posted August 4, 2005 11.5.1 renders faster than 11.5 according to my own test files, but still a lot slower than 11.01 - and before anyone suggests it, yes, I've repaired permissions several times, the only PIO i've used is a call-out and I only use helvetica. My results for my dual2MHz G5 1.5G Ram (in seconds): HLR, 8 view ports test: VW11.01/11.5/11.5.1 - 15/145/118 Final RW test:VW11.01/11.5/11.5.1 - 10/18/18 (no change!) Custom RW (Ray trace Level3):VW11.5/11.5.1 - 33/24 (37% faster) HLR single model test: VW11.5/11.5.1 - 27/18 (50% faster) So I'm pleased to have the update, but I look forward to further improvements. David Quote Link to comment
islandmon Posted August 4, 2005 Share Posted August 4, 2005 DDD .. muchas gracias ... shall sleep better tonite ... and this test explains way HLR is such a pain ... Quote Link to comment
Administrator Pharr Posted August 10, 2005 Administrator Share Posted August 10, 2005 Hi everyone, I like to see these numbers posted like this as it gives us something to work with. It looks like from what has been posted here that the slowdown we're talking about is hidden line rendering and final RenderWorks slowing down significantly between 11.0.1 and 11.5.0. Is this what everyone is talking about? If DD and APE could send files to my email address below which demonstrate these slowdowns, we will very likely be able to do something about it. Otherwise it may be difficult to make headway on this issue. When sending files, please use a very descriptive subject line to avoid your mail being confused with SPAM. Thanks, pharr@nemetschek.net Quote Link to comment
APE Design Ctr Posted August 10, 2005 Author Share Posted August 10, 2005 Hi Paul, I would be happy to send a few examples along. My files are quite large, even when zipped. (10-15 megs) How would you like me to give them to you. Eddie Quote Link to comment
Administrator Pharr Posted August 10, 2005 Administrator Share Posted August 10, 2005 If you just zip them and send them to my email address, that should work. If you have trouble doing that, I can give you an FTP site to which to upload them. Let me know. Thanks, Paul Quote Link to comment
Vectorworks, Inc Employee Walid R. Posted August 16, 2005 Vectorworks, Inc Employee Share Posted August 16, 2005 David, Here are some test results from the test file you sent us. Hidden line rendering is faster in 11.5.1 than in 11.0.1. Can you give us some steps on how you are getting different results with HLR ? Results w/OSX(10.4.3) on a Dual 1.8Ghz G5/ 1GB RAM: HLR test: 11.0.1/ 3D conversion res 'Very High' --> 30 secs HLR test: 11.5.0/ 3D conversion res 'Very High' --> 20 secs HLR test: 11.5.1/ 3D conversion res 'Very High' --> 20 secs the other issue with the Hidden line rendering being slower when the 3D Conversion Resolution is changed from 'Low' to 'Very High' is something we are currently investigating. Walid Remaili Quality Assurance NNA Quote Link to comment
islandmon Posted August 17, 2005 Share Posted August 17, 2005 In my recent experience 3D Conversion Resolution is significant to 11.5.1. Much more so than with early versions. Changing from med > high will cause a sudden slow down especially in the Class Menu ! Quote Link to comment
APE Design Ctr Posted August 17, 2005 Author Share Posted August 17, 2005 Pharr, I just emailed you a typical project. Pls do the test on 'Update all viewports'. This will give the machine and the software some good time to work through the renderings. I usually render all viewports, then go and do some other things regarding the project in Excel. In 11.01, I am usually just finishing up the Excel stuff, when the viewports complete all their rendering. Now on a typical project I have finished with Excel, and I am waiting around for the renderings to complete. I bet 11.51 is slower by 30%+ in updating viewports in my estimations. Let me know how you make out... Thanks Quote Link to comment
