deepImplement
VW connection to Ecxel via ODBC doesent work
Heyo,
I just tried to connect VW 2019 with a Ecxel document over the ODBC connection to transfer data.
I try to use this Tutorial from @Miguel Barrera
The Problem I have is when try to choose the dataconnection in VW, the options are not givin:
I create connections in the ODCB Manager tfor every Ecxel Driver who exist:
Why isnt this working in VW?
I try to run VW with Admin Rights but still no result in the list.
1 answer to this question
In windows there are multiple copies of odbcad32.exe so you need to find which one is visible to VW. I did a search on the windows folder and found 4 copies. The most relevant however, are located in the C:\WINDOWS\SysWOW64 folder, which applies to 64 bit applications, and the other is in the C:\WINDOWS\System32 folder, which applies to 32 bit applications. If it does not appear in the VW dialog, then you need to configure the other odbcad32 administrator.
In my system, I found that the one in SysWOW64 works with VW.
