Mike Swift Posted July 27, 2005 Share Posted July 27, 2005 This is weard but when I try and use VectorWorks help everything starts ok, but when I select a page in the left pane nothing happens in the right one. It just stays with the "front" page. This makes it hard to use the help system Has anyone seen this problem, and found out how to fix it. Quote Link to comment
Suporte Técnico Posted July 27, 2005 Share Posted July 27, 2005 Use Safari for it and also, try to see if is there any update for it available. On its previous versions it had some problems to show VectorWorks help. Quote Link to comment
Guest Posted July 27, 2005 Share Posted July 27, 2005 You may need to clear the cache too. To do this, click on the menu called Safari and select Clear Cache. Quote Link to comment
Mike Swift Posted July 27, 2005 Author Share Posted July 27, 2005 Thanks Katie, and Mario, updated and cleared cache, problem solved Quote Link to comment
