GGC
Newbie Repeat Dialog Value ForEachObject inquiry
I have been attempting to complete a simple VS dialog input for the CallOut PIO text margin based on Page Units.
So far, i was successful to repeat the dialog for each of the selected PIO.   I have researched extensively how to pass
the dialog value input (once inputed) for each PIO selected, however I could find the appropriate answer at least for
my VS newbie lexicon.
I am attempting to pass the Dialog Value inputed once to the Procedure to repeat for each selected PIO.
Could anybody share a bit of VS wisdom about how to pass the Dialog Value inputed once to repeat ForEachObject?
Initial VS that obviously requests a dialog input for each selected PIO:
Procedure SomeCalloutMrgnDialog;
Var
    H1:Handle;
    B1:Boolean;
    MrgnCall, MrgnValue,LyrScale:Real;
    MrgnValueStrng,default,request:String;
Procedure SetObj_Value(H1:Handle);
Begin
    request:='CallOut PIO Page Unit Margin';
    default:='0.0625';
    MrgnCall:=DistDialog(request,default);
    H1:=FSActLayer;
    LyrScale:=GetLScale(ActLayer);
    MrgnValue:=LyrScale*MrgnCall;
    MrgnValueStrng:=Concat(MrgnValue);
    SetRField(H1,'Callout','Margin',MrgnValueStrng);
    ResetObject(H1);
    SetDSelect(H1);
    End;
Begin
    ForEachObject(SetObj_Value,(((VSEL=TRUE) & (PON='Callout'))));
    DoMenuTextByName('Previous Selection',0);
End;
Run(SomeCalloutMrgnDialog);
After my extensive research an attempted VS to repeat the Dialog Value for each object.  Though, after I input the value once
for more than one selected PIO nothing happens.
Var
    H1:Handle;
    B1:Boolean;
Begin
    default:='0.0625';
End;
Var
MrgnValueStrng: String;
Begin
    ResetObject(H1);
    SetDSelect(H1);
    End;
Procedure Last_Step_Proc;
Begin
End;
Try this slight variation (untested):
Var
    H1:Handle;
    B1:Boolean;
Procedure GetValues;
Begin
    default:='0.0625';
End;
Begin
    ResetObject(H1);
    SetDSelect(H1);
End;
Begin
    GetValues;
End;
Thank you Julian, your revision works.
I appreciate you taking the time to revise my newbie attempt.
I have been attempting to further revise the script to work inside groupts, symbols, and viewport annotations.
Though I used the GetParent to obtain a handle of the container (group, symbol, or viewport) for GetLayer to use for GetLScale
the factor that I need to use for page units the script will find the CallOut PIO however not the the handle for the layer thus
GetLScale=0, thus obviously the text margin set will become 0 (zero) for CallOut PIOs in groups, symbols, or viewports.
I have researched in the forums and noticed that for some reason VS needs a handle for each specific container condition other
than design layers, that is a quite a puzzle.
Could anybody share a thought if there is the possibility to obtain a handle for each CallOut PIO regardless of the container or not to use for GetLscale(GetLayer(GetParent(CalloutPIOhandle).
Procedure SomeDialogValue;
Var
    H1:Handle;
    LyrScale, MrgnCall, MrgnValue :Real;
    Default, Request, MrgnValueStrng : String;
Begin
    Request := 'CallOut PIO Page Unit Text Margin';
    Default:= '0.03125';
    MrgnCall := DistDialog(request,default);
    If NOT DidCancel Then BEGIN
    End;
    End;
Procedure Callback(H1 :Handle);
Begin
    MrgnCall := MrgnCall;
    LyrScale := GetLScale(GetParent(H1));
    MrgnValue:= LyrScale*MrgnCall;
    MrgnValueStrng := Concat(MrgnValue);
    ResetObject(H1);
    SetDSelect(H1);
End;
Begin
    If NOT DidCancel Then GetValues;
    If NOT DidCancel Then ForEachObject(Callback, ((INSYMBOL & INOBJECT & INVIEWPORT & (PON='Callout') & (('Callout'.'Bubble Style'='None')|('Callout'.'Bubble Style'='Vertical Accent Bar')))));
End;
Run(SomeDialogValue);
