In 2019 and before it was common practise for me to use the 2d polygon tool to create profiles to extrude. Sometimes with single extruded lines, sometimes more complex 2d polygons.
I noticed first that a vw2019 project opened in vw2020 all of the extrudes that are created from single lines lost their fills. I had to convert them to generic solids to give them back their fills.
Also I noticed that if I wanted to create a new extrude from a sinlge polygon /line that they did not have a fill and I could not change that fill. I can create extrudes from sinlge lines with a fill if my attribute palette is set to class style at the moment of drawing it., but still it can not be edited afterwards.
About a month ago I was having issue with disappearing fills in cloud rendering for which I posted the topic below. I am now thinking that this is caused by the same issue. I think at that time the cloud rendering was already updated to 2020 causing the behaviour.
Sebastiaan
Hi All,
Has anybody else had the same experience?
0 answers to this question
