josue Corona Posted November 13, 2019 Share Posted November 13, 2019 Hello, Does anyone know why when I make a symbol and then I try editing it, the 3d object disappears when I am in open gl mode. I am using vectorwork 2019 spotlight . Thanks Quote Link to comment
Pat Stanford Posted November 13, 2019 Share Posted November 13, 2019 Is this a hybrid symbol? In Hybrid Symbols there is a separation between the Screen Plane (top/plan and elevation views) objects and 3D objects. You can normally only see one set at a time. It is possible that you have an "almost" 3D symbol with just a locus point or something similar in screen plane making it hybrid. If you edit the 2D portion you will not see the 3D parts. Quote Link to comment
josue Corona Posted November 19, 2019 Author Share Posted November 19, 2019 Hey there Pat, Thank you for your response, but it was something different. The problems was the UNIFIED VIEW was activated . Quote Link to comment
Pat Stanford Posted November 19, 2019 Share Posted November 19, 2019 Were you trying to display some objects in Top/Plan and other in a different view? All (and that is a very big understatement) Unified View does is change the view of all the visible layers to match the view of the active layer. So when you switch from Top/Plan to Front, all of the layers switch to Front. Glad you got it working for you. Quote Link to comment
josue Corona Posted November 20, 2019 Author Share Posted November 20, 2019 No. I am in design layer. So I am making a 3D object (wall) after I made the wall I turn it into a symbol. So whenever I wanted to go into that symbol and edit something out of the wall . whenever I was in that symbol edit (open gl) the object will basically disappear and go somewhere else in the design layer. So my rendering open gl shape would be in top let corner and my actual object would be somewhere down in design layer invisible. But removing the Unified Views fixed it . Quote Link to comment
