mlance Posted November 7, 2019 Share Posted November 7, 2019 (edited) Using James Thomas 20.5 x 20.5 Supertruss. Laying out a simple grid. I can corner without issue. When I try to "T" a truss and use a gate it all breaks down and I get loads of errors. What am I doing wrong? Attached is an example of what I am talking about. Also - why do the gates default to the middle of the truss and work BUT when you move them to the correct position they fail? Edited November 7, 2019 by mlance Quote Link to comment
Vectorworks, Inc Employee JustinVanHassel Posted November 7, 2019 Vectorworks, Inc Employee Share Posted November 7, 2019 @mlance What version of Vectorworks are you using? In VW2020 the gates were setup to properly work with the auto connect feature. Quote Link to comment
mlance Posted November 7, 2019 Author Share Posted November 7, 2019 This is 2020. I used auto connect for the gates. they get placed in the middle of the truss still. And there is no way to "T" a truss with the auto connect.It just goes to the end of the existing truss run. I had to move the truss into position manually. Quote Link to comment
Vectorworks, Inc Employee JustinVanHassel Posted November 7, 2019 Vectorworks, Inc Employee Share Posted November 7, 2019 Please post your file if you are able/allowed and I will take a look and make it work if I can. I will probably have to make a duplicate symbol as I only set up the gates to function as traditional corners and not T-Corners. If you can't post your file please let me know what gates you are using and I will send you a replacement symbol. Quote Link to comment
mlance Posted November 7, 2019 Author Share Posted November 7, 2019 I am using the James Thomas Super Truss B1304 gate. Quote Link to comment
Vectorworks, Inc Employee JustinVanHassel Posted November 7, 2019 Vectorworks, Inc Employee Share Posted November 7, 2019 This should work for you. To connect the lower T you will have to hover pretty high on the symbol as the rest of the T is missing because it is made of the other straight pieces of truss. Let me know if you have issues, I tested it and it worked for me. JThomas B1304 T.vwx Quote Link to comment
mlance Posted November 7, 2019 Author Share Posted November 7, 2019 This works. Thanks! Quote Link to comment
Nelson Mandela Posted January 4, 2021 Share Posted January 4, 2021 I am looking for James Thomas 3D symbol for Super Truss 76 x 52 and Tower Elements 38 x 38. can anyone share. Please. Thanks. Nelson Quote Link to comment
