Christiaan Posted November 7, 2019 Share Posted November 7, 2019 (edited) I'm working on my first project where we'll be co-ordinating with the structural engineer via IFC. It's not a BIM project contractually and we haven't produced a BIM execution plan or anything like that, so it's relatively informal, but I'd like to set some protocols in place and give them a heads up on any potential issues. For instance we once received an IFC model from an engineer that wasn't broken down into storeys. It came as one object. So I requested that the model be broken down properly into storeys. I also notice ISO BIM standards require models to be shared via real world co-ordinates, rather than using a local origin. What's the best way to go about this at my end? Does this mean setting up a set of design layer viewports with my model set to real-world co-ordinates? Or a workgroup reference file? Or would it be easier just to ignore this standard and use a local origin point and orientation? Is there anything else worth mentioning to the engineer that will make the process smooth? Edited November 7, 2019 by Christiaan Quote Link to comment
Christiaan Posted November 7, 2019 Author Share Posted November 7, 2019 (edited) Interestingly these pages mention nothing about exporting to real-world coordinates and orientation: http://app-help.vectorworks.net/2020/eng/VW2020_Guide/IFC/Workflow_IFC_export.htm http://app-help.vectorworks.net/2020/eng/VW2020_Guide/IFC/Exporting_IFC_projects.htm Edited November 7, 2019 by Christiaan Quote Link to comment
Hans-Olav Posted November 7, 2019 Share Posted November 7, 2019 Hi Christian. I really don't know what the standards say but we have some experience charing IFC the informal way. I would recommend you to choose your origin as it practical for you. Axis A-0 or somewhere but its good to know the true co-ordinates, then you always can adjust later if it is necessary ( from a referenced export file ) Usually the Architect starts the project and if you export early the other consultants will adapt their stories and origin to you. (-: 2 Quote Link to comment
