antonf26 Posted November 5, 2019 Share Posted November 5, 2019 (edited) I can't seem to figure out how to space the data tags evenly. They always seem to overlap and I´ve tried every single combination. I´ve tried putting a larger box around the tag layout so maybe there would be space between them but that doesn´t seem to work. The parallel one doesn't work because you still get overlaps if there are two plants on the same level. As for the aligning them equally, all the tags just seem to stack up onto each other. Is there a way to set a distance between the tags? The top image is aligning by equal distance. (I also made a long line so they could spread across that but for some reason they love grouping together) The bottom one is the parallel. Edited November 5, 2019 by antonf26 Quote Link to comment
Vectorworks, Inc Employee Tamsin Slatter Posted November 5, 2019 Vectorworks, Inc Employee Share Posted November 5, 2019 Manually align the top two tags to have the distance that you want. Then select all the plants, run the command again, and it will use the distance between the top two as the uniform distance between them all. 3 Quote Link to comment
