Hello Community!
This Saturday, April 11, from 9am – 1pm EDT we will be performing maintenance on the Vectorworks Community Board. During this time, the site will be unavailable.
John Harris
2020 not responding/hanging/crashing while opening file at resetting bounds
Hi,
I have just installed 2020. I have been working on a drawing which I now can't open. When I open it vectorworks stops responding at 'resetting bounds'. I can open an empty drawing and I can open files created in other versions pre2020. I only have one 2020 file and it and none of it's backups will open.
Thoughts?
system is
mac powerbook 13" 2017
3.1 ghz intel core 5
8gb memory
Intel Iris Plus Graphics 650 1536mb
sw 10.14.6
8 answers to this question
@John Harris Go to Vectorworks Preferences>display and switch Navigation Graphics to Best Compatibility and try the file again. If the problem persists, go ahead and send me the file via Direct Message, and I'll be happy to check this out and confirm if the issue is file specific or a Graphics Card issue.
@JuanP the display preference was already set to best compatibility so unfortunately not that. I uninstalled and reinstalled vw then I was able to open the file. I didn't change the font mappings which I had done before, probably not related, I then purged the drawing. I have been working with it most of today and currently no issues, except it is moderately slow to react especially with nudges. Happy to send you both the current file and an old backup pre purge for your views.
I eventually just left it opening for about 30mins and walked away, once it opened I purged the drawing of unwanted symbols and stuff and it has been ok since. Worth a try.
I started to purge the unused classes 10 minudes passed I am still waiting...I will sure wait for max 30 minutes.
ıs this realy okay?
help - similar problem, it sounds like?
just updated to 2020 Architect, this morning, from 2019.
I thought it had to do with a faulty installation, but I can open some files but not the one I needed to work on.
It crashes while opening - it says 82% generating Resource previews, then it shuts down.
repeatedly.
I tried the suggestion above for navigation graphics to "best compatibility", no luck.
also, should I delete VW2019?
my system:
wdws 10pro - 1809
intel corei7-4770 cpu @3.40ghz
16.0 GB RAM
64bit os  x-64-based processor
thanks
niagara, if you want to send me the file I can see if I can open it and send it back in saved in 2020 version. I have spotlight not architect but it might work.
If you download the free viewer can you open the file.
can you still open it in the 2019 version? If so then purge it and save it then try.
Export as a 2018 file and open that. Does that work? I have had the same happening with 2018 files that were opened and saved in 2019. the original 2018 files were fine but the 2019 files froze 2020 on open. Not sure if saving back to 2018 will work the same but it's worth a shot.
