unearthed
Randomize symbols on a grid
I want to joggle the positions of a lot of symbols that are on a grid. I've seen randomize scripts in the past but searching has come up dry. Does anyone have a script that will at least randomize a rectangular or square grid?
Ultimately I hope to randomize symbols on a radial grid - see encl, but that may be a script to far.
The case is an experimental acoustic planting based on sonic crystal theory.
Randomize grid of symbols.vwx
@unearthedHi, you can do this with Marionette but i notice you have 2012 and i cant export back that far.
This script randomizes symbols within a polygon. You can scale and set the percentage of density of the planting also.
There are 2 d symbols also so you can randomize any symbol you need.
HTH
Randomize trees.vwx
Edited by Alan Woodwell
Hi Alan, The Marionette looks amazing. Are you saying there is also a script that will work in 2012 just for doing 2D random arrangements?
I cannot open the file
@unearthedhi,
2018 attached. When you are happy with the layout you can explode the block of trees so you wont accidentally change the layout. Keep a copy of the object as a backup
To change the polygon right click the trees and edit control geometry. Either change it or draw a new one and delete the old.
Randomize trees v2018.vwx
