The Grid Bubble tool needs to have more control over graphics and the ability to control visibility better.
We need to be able to control all elements by class.
Currently the grid lines have no ability to change graohically when referenced to another file, because control is by an instance parameter. Instance parameters are useless when re-using the data either between files, or even with one file across multiple viewports, so they don't work in any context other than when you are just doing a drawing, which is a bit last century...
We need to turn off the grid dimensions on some drawings so as not to duplicate information unnecessarily.
We need to be able to use a symbol as the grid tag to standardise the graphics across the practice.
shorter
Perhaps we needs Grid Bubble 'styles'?
1 answer to this question
