Pamela Posted April 15, 2004 Share Posted April 15, 2004 When I try to use the tiling command through the AEC menu, it goes through the motions but nothing appears in the 2d polygon I am trying to fill... is this a bug in the program or am I doing something wrong? PSH Quote Link to comment
Guest Posted April 16, 2004 Share Posted April 16, 2004 Double click on the Pan Tool (looks like a hand in the 2d tools palette) to see if the tile shows up. Sometimes you have to refresh the drawing for the tile to be visible. Quote Link to comment
Pamela Posted April 16, 2004 Author Share Posted April 16, 2004 Tried refreshing with no luck, not certain my refresh tool is working either, when I double click on it I get no response. I almost wonder if I should try to completely reload the program. I have yet to get some of the surface construction commands to work correctly wither, still cant build a surface and modify it. Even when i add 3d polygons and modifiers it updates the surface and does not reflect the modifications I was trying to make. Needless to say it has been very frustrating. Any suggestions?? Thanks for your help Quote Link to comment
Vectorworks, Inc Employee Robert Anderson Posted April 22, 2004 Vectorworks, Inc Employee Share Posted April 22, 2004 Pamela, please send me a copy of the file with JUST the symbol that you want to use for tiling. Email to randerson@nemetschek.net Thanks! Quote Link to comment
stevem Posted June 7, 2005 Share Posted June 7, 2005 Any resolution to this issue? I'm encountering the same problem with 11.5.0 (Windows) with the latest Vectorworks patch. Quote Link to comment
Pamela Posted June 14, 2005 Author Share Posted June 14, 2005 I honestly don't remember, I think I finally got it to work, but I don't use that function enough to remain fluent in its use. Sorry I couldn't be of more help, maybe Robert will remember. PSH Quote Link to comment
