I'm having issues exporting shapefiles from VW2020 files which have the geo-referencing settings switched on as default.
If I select a simple polygon within a georeferenced / geolocated file, and navigate to File > Export > Export Shapefile; I typically then would choose selected objects, keep projection, and write .prj file (and choose all additional object data). When I do this and click OK, I am prompted where to save the file, and click OK again. Nothing happens, and no file is generated.
What I'm having to do as a workaround is open a new file, turn off all the geo-referencing settings, copy / paste in place my polygon to the corresponding X Y location to the co-ordinate position, and then go through these steps again for a shape file to actually output? Is this a bug or is there a flaw in my workflow somewhere?
