VW_Harry Posted October 31, 2019 Share Posted October 31, 2019 forum_Test.vwx forum_Test.vwx forum_Test_v2016.vwx Quote Link to comment
markdd Posted October 31, 2019 Share Posted October 31, 2019 (edited) Looking at your file, the rotation of the instruments is technically correct. I think that perhaps you may be misunderstanding the way the LIghting Tool uses the rotation axes. The rotation axes refer to the rotation axes of the instrument inside the symbol and not necessarily the Axes on the current layer plane. This is logical but not necessarily helpful to you right now. Your issue where the rotation of the Top/Plan view does not necessarily align with the flipped 3D object has been addressed in Version 2020 with the addition of the Custom Plan Rotaton check box, which will allow you to rotate the 2D portion independently of the 3D portion. I've added some Axis markers to one of the instrument symbols to help explain what is going on..... I hope that's helpful. added axes.vwx Edited October 31, 2019 by markdd Quote Link to comment
VW_Harry Posted November 1, 2019 Author Share Posted November 1, 2019 22 hours ago, markdd said: Custom Plan Rotaton Hi Mark, I found the Custom Plan Rotation!! That's is new!! Another question! When the VW20 downgrade to older version ( I tested with vw16). the floor light's Z axes are not correct. I checked Set 3D Orientation. X Rotation is 180. forum_Test.vwx forum_Test_v2016.vwx Quote Link to comment
markdd Posted November 1, 2019 Share Posted November 1, 2019 It appears you have discovered a bug! The Y rotation of the Lighting Device does not seem to work and the value entered is applied to the X rotation field instead. I'll report it as a bug. 1 Quote Link to comment
VW_Harry Posted November 28, 2019 Author Share Posted November 28, 2019 Hello Mark, I updated my vw to SP2 today. it seems like we still have a problem...do you know when it is going to fix? Thank you Quote Link to comment
VW_Harry Posted December 9, 2019 Author Share Posted December 9, 2019 Hello Mark, Would you let me know when the bugs are going to update? Thanks~ Quote Link to comment
