MaryBea 0 Posted October 29, 2019 The black box in the attached exported image is a 3d photorealistic image prop from the VW library. The rendered image pre export is fine. Would anyone know why this is happening? When I lower the export resolution to below about 120 the tree appears but the image is very blurry. Thanks for any help. Bea VW 2020 macOS Mojave 10.14.6 iMac 2019 Quote Share this post Link to post
Kevin Allen 242 Posted October 29, 2019 This is renderowrks and not OpenGL? Quote Share this post Link to post
MaryBea 0 Posted October 29, 2019 Yes, renderworks. File attached. Thanks. test.vwx Quote Share this post Link to post
Kevin Allen 242 Posted October 29, 2019 When I render and export from the design layer, I see the issue. When I put the camera view on a Sheet Layer as a SLVP, render and export, the tree is there. Although I think it should work from the design layer, I also think there are known issues with rendering on design layer and using SLs is considered best practice. test.vwx Quote Share this post Link to post
MaryBea 0 Posted October 29, 2019 That's worked. Thank you so much. I'll use that method from now on. Quote Share this post Link to post
