Sophie Hope Posted October 26, 2019 Share Posted October 26, 2019 After importing a DWG into Vectorworks, I have adapted all lineweights only to then export as PDF and have it come out in jagged lines. I have set all possible resolutions to 300dpi on sheet layer, on Publish and on the basic export to PDF setting. I have no clue why this is happening so any help would be great. Thanks Quote Link to comment
zoomer Posted October 26, 2019 Share Posted October 26, 2019 Are the Objects far from Internal Origin or do they show a Scale Value in OIP ? Quote Link to comment
Sophie Hope Posted October 27, 2019 Author Share Posted October 27, 2019 @zoomer they're on the internal origin and no scale value showing in OIP, not as i can see anyway... Quote Link to comment
Sophie Hope Posted October 27, 2019 Author Share Posted October 27, 2019 @zoomer i'm importing as a dwg from sketchup if that makes any difference Quote Link to comment
zoomer Posted October 27, 2019 Share Posted October 27, 2019 That was just an idea. I had similar very thick lines in a garden plan DWG. Obviously originated from a VW landscape architect. The problematic lines may have come from a referenced DWG into the VWX (?) You couldn't read anything when zooming out. I do no more remember what the problem or solution really was. I think the Line Weights were fine in Attribute or Class Palette, but even appeared when "Show Line Weights" OFF (?) It must have worked either by switching between by Class vs by Object assignment, by reassigning a new Line Weight or that I found any strange Scaling anywhere. But your lines seem to appear OK on Design Layers, just strange on Sheet Layers and/or PDF output ? So it is likely a completely different problem ? Quote Link to comment
