drelARCH
VW 2020 changing type of Keynote Display causing app to crash
Changing Keynote Display from dotted one to not dotted crash whole application.
I would like to use/convert dotted Keynote legend (from 2019 vw file) to new not dotted one but it is crashing software.
Known bug?
Pavol
11 answers to this question
@drelARCH I couldn't replicate your issue, chances are is file specific. Any chance you can send us your file via private message for testing?
I have successfully uploaded file through provided upload link.
Hope you can replicate issues.
Thanks.
I was able to replicate it. We submitted the issue VB-166051. A couple of findings: 1- Seems like is file specific, I can't replicate the issue in new files. 2 - Changing the Buble Display setting to By Callout fixes the issue.
will keep you posted
May I add to this post with a similar issue?
I am seeing Keynote Legends behaving strangely - on my laptop AND PC. See attached file.
When I edit the keynotes, or any edits that relate to them, they grow very large. I have to "update" them, but the Note Text Indent jumps to a large number. I cannot replicate it purposely. It just happens.
I've updated my drivers, what's up with this? VW2020 has been a bit unstable and it's frustrating.
Hello Lee,
Could you provide test file and/or record a video. I need more information to be able to check what is behind this issue.
Thanks.
Just to add to the above; we are seeing the same issue with keynotes displaying exceptionally large following any adjustment to the note database or adding/removing callouts in a viewport in VW 2020 Sp2. I find that if i adjust the 'note text indent' on the keynote back to a reasonable value (ie. 5mm) it corrects all the values. Happens every time you adjust notes / callouts. Very frustrating
Hi JPM,
I tried to reproduce the behavior described above with new and old files but with no success. Maybe this is file specific bug and I can't find where the problem is if I don't have your files and steps to reproduce.
@iborisov Sent you my file via private message. Can i also note that this file also demonstrates an issue I have raised with roof face components in a separate thread. Thanks
2 hours ago, iborisov said:
Hi JPM,
@iborisov, I checked it with two recent files. It behaves the same when modifying a keynote.
Here is a link to a video. I'll upload the video later in case this link doesn't work or stops working.
https://photos.app.goo.gl/JR239xHhQs6JmSDD6
