Sheet layer naming in accordance with BIM standards
Christiaan
How do people go about naming their Sheets in accordance with ISO 19650/BS 1192?
In the attached examples there are a number of codes before the drawing number and then descriptive text after the drawing number. The only way I can see to make this work is to include all the codes in the Sheet Number and then the descriptive text in the Sheet Title. Is that what you do?
659302249_Screenshot2019-10-22at13_02_18.thumb.png.9b9af08cf7e2a46d3d43cb9215e7ff9c.png
The other little issue is this. ISO 19650 requires that no spaces are used in file names, but that means we end up with this kind of thing in our title blocks. Any thoughts?
1560589922_Screenshot2019-10-22at13_19_23.thumb.png.0c6b49aa80f324a824835840332fa359.png
Edited by Christiaan
  • 2 years later...
  • 2 years later...
@Christiaan The sheet number simply needs to be the n digits sequential/logical number at the end (e.g. 120100).  The rest of the titlesheet should contain the fields required, and in conjunction with dynamic text fields in the titlesheet, and the publish command, generate the full ISO19650 document number by concatenation.
