Nebeor
VWTransform : void SetRotation(VWPoint3D newZ, VWPoint3D newY); unable to compile
I tried to use VWTransform's void SetRotation(VWPoint3D newZ, VWPoint3D newY);
Unfortunately the compiler complains with LNK2019: unresolved external symbol.
I have encountered this bug earlier on, but strange enough, I succeeded yesterday to compile, but I was not able to do the same today.
Am I the only one who has issues with this function? I cannot make sense out of this situation.
VW SDK 2015? I cannot remember having such a problem back then.
Does it compile when you rebuild everything but not when you compile it thereafter? Or vice-versa?
Can you post the complete LNK 2019 error? I would like to see if the C++ mangled name correspond to the signature.
Here you have the complete error:
Error    LNK2019    unresolved external symbol "public: void __cdecl VWFC::Math::VWTransformMatrix::SetRotation(class VWFC::Math::VWPoint3D,class VWFC::Math::VWPoint3D)" (?SetRotation@VWTransformMatrix@Math@VWFC@@QEAAXVVWPoint3D@23@0@Z) referenced in function "public: bool __cdecl NotRelevant::NotRelevantMethod(double &,double &,double &,double &,double &,double &,double &,bool &,char * * &,bool)" (?NotRelevantMethod@NotRelevant@@QEAA_NAEAN000000AEA_NAEAPEAPEAD_N@Z)
However I am checking the VWSDK 2016 (the oldest I have still available here)
VWTransformMatrix.h seems to declare that function, but I cannot find a definition for it, neither inline in VWTransformMatrix.h nor in VWTransformMatrix.cpp.
I suppose that it was already the case in 2015. It seems to be still the case in 2020 (even if there is a function more, but that exact signature is still only declared not defined.)
Therefore I suppose that you will have to compute your rotation another way, for example using matrix multiplication.
void SetRotationMat(VWTransformMatrix& matrix, VWPoint3D& normal)
	double phi = atan(normal.y / normal.x) * kDegreesPerRadian;
	double theta = acos(normal.z / 1) * kDegreesPerRadian * (phi > 0 ? 1:-1);
	matrix.RotateZBefore(phi);
	matrix.RotateYBefore(theta);
I made this workaround, it works for me!
Edited by Nebeor
