MaltbyDesign 6 Posted October 21, 2019 For some reason when I change the texture on my site model, the texture only changes on the 'skirt' and not on the surface of the ground itself. The attached screen shot shows the lighter grass on the skirt, which I can't seem to apply on the surface, which is stubbornly remaining the dark green gras texture. The texture is in my class "site-model" and I can't think of any other place to look to try and change the surface texture. What am I missing? Thanks in advance. Quote Share this post Link to post
Wes Gardner 311 Posted October 22, 2019 @MaltbyDesign...mine seems to work OK. In the Graphic Properties dialog, I set "3D Fill" to a Class (in the example it's called "Turf") and then in the class structure, set that class's Texture to something like grass and it seems to "take." Additionally, when that class's texture is changed, the site model reflects that change. This is when I'm using the 3D Extruded Contours option. This kind of resembles that stepped look we used to get in A-school when we built site models from foam core or cardboard. Is this what you're trying to do? Additionally, if I use the 3D Mesh option in order to get smooth terrain, I had to set the 3D Triangles category also to the class called "Turf"." Wes 1 Quote Share this post Link to post
MaltbyDesign 6 Posted October 22, 2019 Hi Wes, Adjusting the 3D Fill didn't seem to work, nor did adjusting the 3D Triangles. I then decided to try deleting the dark grass texture from the resource manager for this model and the drawing updated to show the lighter grass texture. I got the result I was after but not sure how! Thanks for your help! Quote Share this post Link to post
AlanW 519 Posted November 1, 2019 @MaltbyDesignHi, Its interesting if you set your site model class to a texture the whole model is coloured the same. if you select the site model and change the texture of the model only the top changes. Untitled1_v2018.vwx 2 Quote Share this post Link to post
MaltbyDesign 6 Posted November 1, 2019 @Alan Woodwell Thanks so much for this bit of information. Very useful! This will help me get a solid 'skirt' with a textured ground surface. Quote Share this post Link to post
