as_named Posted October 21, 2019 Share Posted October 21, 2019 Hi I need to create a Roof Face. It should have rectangular shape with predefined thickness. Here is my code: vs.BeginRoof(roofAxisPoint0[0], roofAxisPoint0[1], roofAxisPoint1[0], roofAxisPoint1[1], upslopePoint[0], upslopePoint[1], rise, run, 1, 0) vs.Rect(rectTopLeft[0], rectTopLeft[1], rectBottomRight[0], rectBottomRight[1]) vs.EndGroup() roofFace = vs.LNewObj() vs.SetObjectVariableReal(roofFace, 170, roofFaceThickness) vs.SetFPat(roofFace, 1) It works and required object is being created. But if I use the 'Clip Tool' (Shift + N) on resulting object then its mesh become ruined (missing faces and edges). I checked it by exporting the object as OBJ and opening in other software. If I set fill style or fill color the mesh become fixed again (same way to check - export to OBJ). Same effect may be achieved by using vs.ClipSurface() function. There is an original tool (AEC/Roof Face...). It works without mentioned issue. I tried to compare created roof faces (my tool and the original): Export/Export Script... and compare {Object Creation Code} sections. First parts are identical but the original tool creates more entities. I don't understand why and I couldn't re-use it in my code properly. So my question is: how to properly create Roof Face objects? I use Vectorworks 2019. Quote Link to comment
twk Posted October 21, 2019 Share Posted October 21, 2019 Confirming this happens to me as well. A workaround is to apply a roof style to the created roof. vs.BeginRoof(roofAxisPoint0[0], roofAxisPoint0[1], roofAxisPoint1[0], roofAxisPoint1[1], upslopePoint[0], upslopePoint[1], rise, run, 1, 0) vs.Rect(rectTopLeft[0], rectTopLeft[1], rectBottomRight[0], rectBottomRight[1]) vs.EndGroup() roofFace = vs.LNewObj() vs.SetObjectVariableReal(roofFace, 170, roofFaceThickness) # vs.SetFPat(roofFace, 1) style='' # import/create a roof style and add to this variable vs.SetRoofStyle(roofFace, vs.Name2Index(style)) vs.ResetObject(roofFace) Quote Link to comment
