KevinR
Insert Connection Tool Crashes
HI,
Currently when I try to use the Insert Connection Tool + Insert Drop from Braceworks,  with any Truss Symbols (Vectorworks or My Own), It hard crashes the software.
I have attempted this with many different truss types and brands. All crash the software. Currently it is unusable for me.
Other options I've tried are the straight truss tool, curved truss tool and combinations with Truss Symbols. All Seem to crash.
Process will go as follow:
Insert Truss symbols to any length
Copy/Paste (or add new truss) above/below current truss.
Add Hoists (Or don't. Doesn't affect outcome)
Proceed to use Insert Truss tool (Vertical offset doesn't affect outcome)
Click Top Truss
The moment the mouse reaches the bottom truss, VWX will freeze and crash a few seconds later.
The most Progress I've achieved was getting x1 connection from top to bottom when using different truss at the bottom. But will crash as soon as inserting a second drop.
Using the Place Structural Element On Top/Below works fine.
My Current Setup:
VWX 2020 SP1
Win 10 64bit
Intel Core i7-7700K @4.20Ghz
64GB Ram
Nvidia Geforce 1080 Ti
1TB SSD
All Drivers and Updates are up to date.
I've tried doing this in VWX 2019, which works 100%.
Opening the same file in 2020 and repeating the same steps crashes.
Any help would be appreciated.
Thanx in advance
I am experiencing the same issue and have sent VW a test file along with the crash log with no response yet.
Hi Guys
I've been trying to recreate your issue in 2020 sp1, but at the moment it is working fine for me (using both the insert drop command or the insert connection tool). Could you PM me your problem files so I can investigate further?
Thanks
Hi Both
So I've reinstalled VWX and did the test again without SP1. Everything was working perfectly.
Reinstalled SP1, problem returned.
@jcogdell , So seems the issue is within SP1.
Hope this helps narrowing down the issue.
Edited by KevinR
Hi Mike
I haven't heard back from VWX since i mentioned that SP1 might be the issues.
If you do roll back, let me know if it helped.
I haven't rolled back yet but I can confirm that the problem does not manifest in VW2019 so I'm just going to take the whole project back to that
There isn't a download for SP0. You have to uninstall VWX and reinstall. Then not download SP1
