nicolas06 Posted October 20, 2019 Share Posted October 20, 2019 Hi, I'm currently updating my moving light library by adding a Hung version with clamps. I built clamps symbols with the base. The problem is when I rotate a moving light, the clamps don't rotate properly and don't stick to the base of the light instrument. What could it possibly wrong in all of that ? Thanx. Quote Link to comment
Mike Wright Posted October 21, 2019 Share Posted October 21, 2019 You need to make the base and clamp into a group with the 'Parts' record format applied and 'Base' ticked. Have a search for videos explaining how to build custom lighting instruments, this explains the roles of the parts record 2 Quote Link to comment
BSeigel Posted October 21, 2019 Share Posted October 21, 2019 @Mike Wright is spot on, let me know if you have any trouble attaching the parts record. I would also suggest editing the clamp, the geometry for the clamp seems like a fairly dense mesh and could hurt performance in your drawing. You also probably don't have much need for wings nuts, washers, etc. I would suggest tracing out the right profile of the lower bracket and extruding it an inch or so. This should significantly simplify the geometry. Quote Link to comment
nicolas06 Posted October 22, 2019 Author Share Posted October 22, 2019 ok, I grouped the base and the clamps together and then attaches the record format with base ticked. All good . Thanx for the answers. 1 Quote Link to comment
