Ride Posted October 12, 2019 Share Posted October 12, 2019 See attached file. There is a line in my viewport (looks like a sill, or header) but I can't get rid of it. Can someone shed some light on this? Vectorworks 2019 Architect, InteriorCAD, SP5.3 Macbook Pro mid-2015, Mojave Thanks why can't I get rid of this line?.vwx Quote Link to comment
0 Kevin McAllister Posted October 12, 2019 Share Posted October 12, 2019 Those lines are usually controlled by the Ceiling>Main Class. It can be confirmed by making a Top/Plan viewport. Your example, however, is a section viewport with Display 2d Components turned on. In this configuration, toggling the Ceiling>Main class has no affect. It may be a limitation or a bug. Unchecking Display 2d Components makes the lines disappear but the end display is probably not what you want. @Matt Panzer is this expected behaviour? Should class control extend to components displayed using Display 2d Components in Section Viewports? Kevin Quote Link to comment
0 Ride Posted October 12, 2019 Author Share Posted October 12, 2019 Hi @Kevin McAllister, I can live the results after un-checking the Display 2D Components. Thank you. But it doesn't make a lot of sense as this is not a 2D component. Plus, why would this be controlled by the Ceiling>Main class when my section line is looking down? Seems counter-intuitive. Quote Link to comment
Ride
Thanks
2 answers to this question
