Edit STL Files
  • 2 weeks later...
Try this:
Open a new vwx file.  In the File menu, click Import. Near the bottom are import file type choices including STL.  Select this option and navigate to the STL file and accept/open.  This should bring the STL geometry into your new file as vwx geometry (probably a mesh).  Not sure if it will be easily editable, but at least it's a start.  If needed, you can export the resulting vwx geometry as an STL file.
HTH
-B
