a2collin Posted October 9, 2019 Share Posted October 9, 2019 Hey guys, I just got my educational license for Vision 2020 that I'm using with Vw2019 but anytime I attempt to export my .esc over to Vision, everything works except for the fact that none of my focus data for my fixtures get sent over. I've tried it with about 5 different files, some with a load of lights and some just barebones. I can't seem to find any way to get it working. Quote Link to comment
BSeigel Posted October 10, 2019 Share Posted October 10, 2019 Have you tried using the Export MVR option and opening that in Vision? Quote Link to comment
a2collin Posted October 10, 2019 Author Share Posted October 10, 2019 @BSeigel I spent a good while this morning with your suggestion but the MVR option doesn't seem to do it either. It also doesn't even render the lights for me. Quote Link to comment
BSeigel Posted October 10, 2019 Share Posted October 10, 2019 If you wouldn't mind sending the VWX file over my way I'd be happy to take a look Quote Link to comment
a2collin Posted October 11, 2019 Author Share Posted October 11, 2019 Sure thing! I won't be using this specific plot for a while but getting it working would be lovely for when I get cracking on it next year! 2019October Forum Theatre v2019.vwx Quote Link to comment
wclights Posted October 31, 2019 Share Posted October 31, 2019 Currently MVR is the only version that will export focus data, however, ESC is the only version that will export color and gobo data so you are kind of stuck with an either/or. MVR should have exported your focus data, but I think you need to export your focus points as well or it won't work. In my experience they import into Vision as invisible in the MVR format so you could give that a go. Quote Link to comment
a2collin Posted November 1, 2019 Author Share Posted November 1, 2019 @wclights So if I wanted to export all my focus data as well as color and gobo, would I need to export and MVR and an ESC file into the same vision project? Quote Link to comment
wclights Posted November 1, 2019 Share Posted November 1, 2019 @a2collin If only it were that simple. Technically that would work but you would just have two versions of the plot one that was focused with no color or gobos and one that was just pointed straight down but with all the color and gobos. In my opinion the best approach is MVR and then adding color manually in Vision, but I have had issues assigning gobos to MVR fixtures so I have to import those as ESC and manually focus. Also have had some fixtures like parnels crash the program while trying to manually add color so be ready for that possibility and save often. Quote Link to comment
