livespace josha
2020 Animation path not working
I created a NURBS curve, set the elevation and dialed in each key-frame with the view I want.
I step through each frame, open the camera a new pane, play the path and all is good.
When I create the movie, regardless of the settings on the "create movie" dialog, the path is incorrect on the rendered movie. It appears as all white, and (I think) it moves around outside or above/below the room before coming into the room I'm working on for the final frame.
attached is a low-res, OpenGL render to show what is going on.
