KingChaos Posted October 2, 2019 Share Posted October 2, 2019 (edited) good morning, i am new to vw and i am kind of spoiled from topsolids parametric and total associative construction what i did not found in vw. The problems i have, drawing wall or floors is that i dont know the exact geometry of rooms or buildings. I have to manage and create interior designs for shops but the measurement of the shops is in the offering phase not totally clear and exact and can only be taken from the rooms, when they are empty (only a few days before the fabrication of furniture). but the measurement for offering will be done in complete equipped old furniture. It is not exact and has to be adjustet. but how? if i modify a wall, the floor will not follow, and so on. 1 weeks before i have to send the construction drawings to the joinery we take the exact maesures of the then empty rooms. It is impossible to redraw, reconstruct or modifying all applied furnitures after i modified the walls f.e. How i can manipulate the outlines/contures of walls with simple parameters, so i can place all the cabinets, counters, shelfs before we got the exact measurements and then "only inscribe exact lengthparameters"? is there even a possibility to use parameters? i did not found anything. 😞 br KC Edited October 2, 2019 by KingChaos Quote Link to comment
Guest Wes Gardner Posted October 2, 2019 Share Posted October 2, 2019 Hi, Slabs can be linked to walls such that when you move a wall, the slab (floor system) will expand or contract accordingly. Wes Quote Link to comment
bcd Posted October 2, 2019 Share Posted October 2, 2019 Take a look at Associated Dimensions. These are Dimensions that no only display the length of a wall as a standard Dimension does but which will actually adjust the wall length when you enter a new value. Quote Link to comment
KingChaos Posted November 24, 2019 Author Share Posted November 24, 2019 But how to Link Something (Lines, square etc) on other objects? @Wes Gardner U meant interiorcad slabs 3d will follow the Wall If i parametrically manipulate their posion in my file? That means for me i need some Kind of orthogonal helping construction (Wall f.e. 0.1 mm thick) to Hold the slaps between my parametric Walls? Especially If i will model a Counter with separate Segments between this helping Walls? Quote Link to comment
