HSP DanS
Wall hatches not visible in Section
We are new to using Vectorworks Architect.
I have created a section of our building, the floor textures are showing up great however the walls are only line work? Attached a screenshot below. Any Ideas?
1925891866_ScreenShot2019-10-01at11_07_32.thumb.png.49e927c6da7f3c9ab55fefd3ec409915.png
@HSP DanS...two things to do - First, the container class that those walls are in (01 Lines) has no fill - giver it a fill.  Second, select the walls and then under the Render tab, in the OIP, in the Mode drop-down,choose "By Component" rather than "By Object".  This will let you see the textures of the components in your walls
That will fix it...
Other classes have no fills...that's why other objects appear in wireframe even when you're in openGL  attached are a couple of screen shots and an updated version of your file.
Let me know if you have troubles.
Wes
SECTION TEST v2019.vwx
Thank you, I have changed the settings as you suggested and has worked for the wall (block) hatches! However not so successful for the insulation tile? The colour of the insulation seems to be visible. Although seems to have worked in the file you sent through....
